1964 Ford Thunderbird Power Steering Fluid
WOLLEYSEGAP
Steering problem
1964 Ford Thunderbird V8 Two Wheel Drive Automatic
What type of fluid is used in the power steering unit of a 1964 T Bird?
Mar 1, 2009 at 7:22 AM
BLACKOP555
  • 10,386 POSTS
your vehicle is designed to run with type A transmission fluid, not made anymore.
you can use type F or type FA instead if you can find that either.
others choose to use power steering fluid instead, but its thinner and you may develop lots of leaks.
but using different kinds might not work well together so you will have to flush out the whole system. refill and bleed of air.
good luck
Mar 3, 2009 at 3:36 PM
