1962 Ford Thunderbird synthetic oil in engine
50,900 MILES • V8 • 2WD • AUTOMATIC
HAROLD WENGRYN
Ijust bought this car and would like to change over to synthetic oil. The engine is a 390 4bl . Would it be a good idea and if so which brands would you recommend?
Mar 18, 2008 at 5:41 AM
BLACKOP555
  • 10,386 POSTS
stick with the same weight/viscosity as suggested, i use the most expensive ones i can find on the shelf and usually i use some Lucas engine stabilizer also! I myself am a Penzoil man, but valvoline is very good also and have nothing against it.
Mar 27, 2008 at 8:52 AM
