Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Electrical
Ignition Switch
Replace/Remove
1961 Ford Thunderbird ignition switch removal '56 ford ,n
1961 FORD THUNDERBIRD
13,500 MILES • V8 • 2WD • AUTOMATIC
ROBERT MCFAUL
MEMBER
1 POST
do I have to have a special tool to remove my ignition switch from dash board
Mar 20, 2010 at 5:58 AM
MERLIN2021
Experienced Mechanic
It helps, but not needed! There is a spanner type nut on it, and you can use a screwdriver tip, in the notch, and tap in the loosen direction.
Mar 21, 2010 at 9:03 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
