1992 Ford Tempo Cold Shift Trouble
TOADYBUM
Hi there. Wondering if anyone can help.
1992 Ford Tempo 2.3L Automatic
I have just recently noticed when my car is still cold, it has trouble shifting from one gear to the next, usually when I am on some sort of incline. I avoid steep hills, as it will only go about 20-30km max and takes forever to get up that hill. I especially notice it in the lower gears. Once I am on the highway, the problem seems to go away.
Anyone have any ideas?
Jul 24, 2006 at 1:51 AM
TAURUSWHEEL
  • 718 POSTS
Have someone scan it for you, trans codes might not set the check engine light, they'll be sitting there in the continous memory,, with any luck there'll be something there to point you in the right direction... most auto parts stores will scan for free, make sure you get the codes...
Jul 24, 2006 at 9:43 AM
Suggested Repair
Have the transmission scanned for diagnostic codes stored in continuous memory, since they may not turn on the check engine light. Many auto parts stores will scan for free; obtain the codes for further diagnosis.
Conversation Summary
The owner of a 1992 Ford Tempo 2.3L automatic reports hard shifting when the car is cold, especially in lower gears and on inclines, while highway driving seems normal. The expert recommends scanning for transmission codes in continuous memory, noting that they may not illuminate the check engine light and that many parts stores scan for free.
