1993 Ford Tempo Hard Downshift
FRENCHMANN
I have a 93 Ford Tempo 4 cyl. automatic, with approx. 103,000 miles. Just recently I have been having problems the the transmission. Going from a sandstill, the car has trouble shifting from 1st to 2nd and I need to push hard on the gas pedlel to get it to shift.After that to get the car to go from 2nd and stay in 3rd, I have to maintain at least 41 MPH. If I go below that, he transmission downshifts hard back into 2nd. This problem started after we had very cold temps and much snow. What's going on?
Feb 19, 2007 at 6:07 AM
CHEVY22
  • 1,375 POSTS
snow is a transmission killer ,
there is an internal problem, check the fluid first make sure it is full and what condition its in , if it is bunred or contains any kind of contamination it needs to be gone through
Feb 19, 2007 at 6:33 AM
BPHILLIPS
  • 6 POSTS
Also check the TV linkage, sometime the plastic grommet that retains it will break and the rod will get jam in the full line pressure postion.
Feb 20, 2007 at 11:06 AM
Suggested Repair
Check transmission fluid level and condition first. If the fluid is burned or contaminated, the transmission needs internal service. Also inspect the TV linkage and its plastic retaining grommet, which can break and jam the rod in the full line-pressure position.
Conversation Summary
A 1993 Ford Tempo automatic has trouble shifting from first to second from a stop and hard-downshifts from third to second below about 41 mph. The issue began after cold weather and snow. Advice is to check fluid level and condition for burning or contamination, and to inspect the TV linkage grommet that can jam the rod at full line pressure.
