TRANSMISSION SWAP
LYNNMO23
HI FOLKS, I'M NEW TO THIS VENUE. BUT HOPE SOMEONE CAN HELP. I WONDER IF THE AUTO TRANS, FROM A 1988 TEMPO CAN BE INSTALLED IN A 1992 TEMPO. ANY IDEAS?
Jan 22, 2006 at 3:40 AM
CERVANCE
  • 10 POSTS
it is possable but check the bolt pattern on both to make sure they will bolt up is the main thing also they should be the same motor if nothing else call a salvge yard and have them do a cross check with the tranny you are replacing with the one you have hope that helps
Jan 22, 2006 at 5:22 AM
