1988 Ford Tempo Headlights Won't Turn On
ITSTOOCOLD
I have a 1988 Ford Tempo and have been having a problem with the headlights. The turn signals and brake lights work fine but the headlights won't turn on. Every now and then they turn on out of nowhere. I checked the fuses and they are ok. The battery clamps and wires look corroded. Could this be the problem? I dont have a problem with anything else electrical. Another problem is the winshield wiper broke right off and I can't get it out. What can i do?
Mar 17, 2007 at 10:14 AM
BHUGG
  • 157 POSTS
Get the battery posts and clams cleaned, however, if the car is working, then the headlights are another issue.
Check for good grounds from the headlamps.
Also, check for a fuse box under the hood and check the fuses there too.
If those fail, you either have a bad headlamp or dimmer switch.
Good luck.
Let the forum know what you find.
Mar 18, 2007 at 5:14 PM
ITSTOOCOLD
Thanks I'll give that a try
Mar 19, 2007 at 4:17 AM
Suggested Repair
Clean the battery posts and clamps, then check headlamp grounds and the under-hood fuse box. If those are good, suspect a bad headlamp or dimmer switch. The broken windshield wiper was not addressed.
Conversation Summary
The owner of a 1988 Ford Tempo reported headlights that would not turn on and sometimes came on unexpectedly, while turn signals and brake lights worked and the checked fuses were good. Corroded battery clamps were also noted, along with a windshield wiper that broke off and could not be removed. The expert advised cleaning the battery posts and clamps, checking headlamp grounds and under-hood fuses, and then considering a bad headlamp or dimmer switch if those checks fail.
