-If I remember correctly, you remove the small triangle shaped trim piece on the inside that's held on with one screw. Once that's removed you should see the mounting nuts for the mirrors. The trim piece is at the front edge of the door panel right on the inside from the mirror.
Matt D.
SPONSORED LINKS
Sunday, January 13th, 2008 AT 6:52 AM
