1988 Ford Tempo Heater Blows Cold Air
ALBERT
  • 20 POSTS
I have a ford tempo year is 1988, and the heater used to work before but i left it sitting in my back yard for about 4 months and now it dont work? So what seems to be the problem? Thank you.
Dec 16, 2006 at 5:15 PM
CARUNDELL
  • 602 POSTS
[quote:3e5e3450bf="Albert"]I have a ford tempo year is 1988, and the heater used to work before but i left it sitting in my back yard for about 4 months and now it dont work? So what seems to be the problem? Thank you.[/quote:3e5e3450bf]
Hey albert,
Are you saying the blower is not working? Or the blower works and it doesn't blow heat. Please be more specific! Let us know
Chris
Dec 16, 2006 at 6:57 PM
ALBERT
  • 20 POSTS
[quote:fbfc2b3af6="carundell"][quote:fbfc2b3af6="Albert"]I have a ford tempo year is 1988, and the heater used to work before but i left it sitting in my back yard for about 4 months and now it dont work? So what seems to be the problem? Thank you.[/quote:fbfc2b3af6]
Hey albert,
Chris[/quote:fbfc2b3af6]
Im not sure, I turn on the heater and air comes out but the air is cold, i leave the car on for a while and it never warms up. so i dont know how do i find out if the blower isnt working?
Dec 16, 2006 at 9:27 PM
CARUNDELL
  • 602 POSTS
[quote:6f9f4d7646="Albert"][quote:6f9f4d7646="carundell"][quote:6f9f4d7646="Albert"]I have a ford tempo year is 1988, and the heater used to work before but i left it sitting in my back yard for about 4 months and now it dont work? So what seems to be the problem? Thank you.[/quote:6f9f4d7646]
Hey albert,
Chris[/quote:6f9f4d7646]
Im not sure, I turn on the heater and air comes out but the air is cold, i leave the car on for a while and it never warms up. so i dont know how do i find out if the blower isnt working?[/quote:6f9f4d7646]
Hey albert,
Some things to check, first though, if air is coming out of the vents than your blower is working.
1. your temperature control operates on engine vacuum, check the small plastic vacuum line that goes thru the firewall, these sometimes crack and break.
2. check the hoses to the heater core, if they are not both hot then is a heater core problem (clogged)
Chris
Dec 16, 2006 at 9:38 PM
BRUCE HUNT
  • 3,754 POSTS
After sitting for that time period and given the age of the vehicle, a lot of time the radiator fluid is neglected. My thought is that the thermostat is sticking and I sincerely recommend a flush of the system and replacing the thermostat.
Dec 16, 2006 at 11:06 PM
Suggested Repair
Because air comes from the vents, the blower is working. Check the small plastic vacuum line through the firewall for cracks, since the temperature control uses engine vacuum. Check both heater-core hoses; if they are not both hot, the heater core may be clogged. After the long sit, also flush the cooling system and replace a possibly sticking thermostat.
Conversation Summary
The owner of a 1988 Ford Tempo said the heater worked before the car sat for about four months, but now the vents blow only cold air even after the engine runs. An expert confirmed the blower is working and advised checking the vacuum line to the temperature control and whether both heater-core hoses get hot. Another expert recommended flushing neglected coolant and replacing a sticking thermostat.
