Wednesday, May 16th, 2007 AT 9:13 PM
Ok I have a 1993 ford tempo and the check engine light is on. So when I grounded the ecc test and turn the key over. It takes a minute but the fans kicks on the off the the check engine light starts flashing but everything is outta sync. On gm models it flashes 12 three times the codes then recycles though again. This is just a mess. It goes "1 1 3 1 1 3 1 1 1 3 2 1 2 1 1 3 2 1 2" then stops. And thats it till I shut the key off then turn it back over. It repeats the exact same thing.
