anyways, ive gotten the power, ground, speakers, and RCA cables hooked up. The only thing left for me to do is run the Amp Remote Turn On Lead wire from the new stereo to the amp.
i didnt think of this when buying the kit to hook all this up. In the new stereo instructions for hooking in an amp, it says "Amp Remote's Max Supply Current is 0.3 A"
i can only think that, that means the wire carries no more than 0.3 Amps of electricity to switch on/off the amp.
the problem that I have is what kind of wire would I need or should I use to hook this bad boy up?
Monday, June 25th, 2007 AT 2:19 PM
