1992 Ford Tempo Dies While Cruising
JAY40998
If I was cruising along in cruise control and the car just shut down and would not start like it was out of gas. Could the fuel pump be to blame or could it be something else? If it is the fuel pupm are there any websites that describe or show the best way to change the pump?
Nov 7, 2007 at 8:41 AM
  • 75,988 POSTS
My question is do you hear the fuel pump come On when you turn key to On position If not could be the pump or a wiring problem/fuel pump relay or computer. Or the inertia cut off switch.
Nov 7, 2007 at 9:09 AM
Suggested Repair
Turn the key to On and listen for the fuel pump. If it does not run, check the pump, wiring, fuel pump relay, computer, and inertia cutoff switch.
Conversation Summary
The owner of a 1992 Ford Tempo said the car shut down while cruising on cruise control and would not restart, as if it were out of fuel, and asked whether the fuel pump was responsible and how to replace it. The expert advised checking whether the pump is heard when the key is turned on; if not, the cause could be the pump, wiring, fuel pump relay, computer, or inertia cutoff switch.
