OK, to start see if the brake lights come on every time you push on the pedal. Find the brake light switch on the pedal assembly, there should be a red/ lt green wire. Use a test light to see if ti is getting 12 volts when pedal is depressed. If so go to th elock solenoid on the bottom of the column, check same wire there for 12 volts as wellas the gray/yellow. If ok, be sure th eblk wire has good ground if it does the shift-lock actuator is bad
Tuesday, February 5th, 2008 AT 7:39 AM
