1994 Ford Tempo wheel bearing
ZIFFELSPIE
1994 Ford Tempo
change the front wheel bearing on a 1994 Ford tempo?
Jul 3, 2009 at 8:59 AM
FIXITMR
  • 9,989 POSTS
as a do it yourself project the only practical way is to get a complete front spindel assembly from the boneyard. because the front bearing is a press fit in the spindel. although it is possible to beat it out then sandpaper the hole to make the new 1 fit in easier. or you can take to shop after you remove spindel and have them do it. like i said, easiest to just get a boneyard spindel. make sure you spin it with hand and detect absolutely NO roughness! it should spin absolutely smoothly! any feeling of a tick/click is NO good! get another 1! have fun!
Jul 4, 2009 at 5:12 AM
