1994 Ford Tempo Valve Cover Gasket
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
KIMRA1962
What are the torque requirements for the valve cover on a 94 ford tempo
Mar 23, 2009 at 11:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If using original bolts to secure cover, apply small amount of Loctite or equivalent to bolts before tightening. Tighten each bolt to 71-106 inch lbs. (8-12 Nm). If using nuts to secure the covers( 3.0L engine) refer to diagram of order of tightening the nuts. Tighten each nut, in order, 8-10 ft. lbs. (10-14 Nm).
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528005d5c5_1.jpg
Thanks for using 2CarPros.com!
Mar 23, 2009 at 12:00 PM
DAVE H
  • 13,383 POSTS
Valve Cover Bolt....INCH Lbs 89-124 Nm(10-14)
Mar 23, 2009 at 12:06 PM
