1994 Ford Tempo stuck at high RPM
LUVGOD555
Engine Mechanical problem
1994 Ford Tempo 4 cyl Front Wheel Drive Automatic
when we start the car(when it finally starts) it revs up and stays there. we replaced the throttle positioning sensor and it was no help. There is no check engine light so I don't know what else to do.
Mar 23, 2010 at 6:37 AM
  • 75,988 POSTS
Check and test the idle air control solenoid if okay also look for vacuun leaks
Mar 23, 2010 at 9:05 PM
