HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Tempo
Engine
Starter
1994 Ford Tempo starter
SCHEDMAN
MEMBER
1994 FORD TEMPO
4 CYL
FWD
AUTOMATIC
189,900 MILES
The starter will not disengage, what causes this?
Wednesday, July 21st, 2010 AT 8:24 AM
FIXITMR
MECHANIC
When did this start happening? Does your car have 2 solenoids? 1 on inner fender and 1 on starter? Have you done any recent work on car? Sounds like solenoid is not disengaging.
SPONSORED LINKS
Monday, July 26th, 2010 AT 1:01 AM
Please
login
or
register
to post a reply.
Related Starter Content
1994 Ford Tempo Starter
I Need To Know Where The Starter Is On My Car; So I Can Try To At Least Get It Home!
Asked by
jennycorliss
1 ANSWER
1994
FORD TEMPO
VIDEO
Starter and Set Points Gap!
Instructional repair video
GUIDE
Starter
An engine starter is constructed as a high torque, high amperage 12 volt motor fitted with an electrical solenoid and Bendix gear which is used to rotate an engine between...
Starter Silenoid
94 Ford Tempo Runs Fine Then One Day It Wont Start. It Does Click When You Turn Over Key. Wont Start
Asked by
zagerwack
1994
FORD TEMPO
1990 Ford Tempo Starter Switch
Been Having Trouble Starting Vehicle, Engines Turns Over But Doesn't Stay Started, Left Me Stranded However If I Held The Starter Switch...
Asked by
lindaroy
1990
FORD TEMPO
1992 Ford Tempo Starter Not Engaging
Electrical Problem 1992 Ford Tempo Car Was Running, But Wouldn't Start When Left Store. Only Get A Single Click When Turning...
Asked by
sopeckham
1 ANSWER
1992
FORD TEMPO
Starter
Starter Doesent Seme To Be Engaging.I Turn The Switch And It Just Gos Wingggggggg
Asked by
Inviziblman420
1 ANSWER
1992
FORD TEMPO
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Motor Replacement
Online car repair manuals
