1994 Ford Tempo Slow responce and speed
1994 FORD TEMPO
30,000 MILES • 4 CYL • FWD • AUTOMATIC
SARGE82375
When the car starts its hesitates when you push on the gas i have did a full tune up and still nothing also when on the freeway once you hit 60-65 miles an hour it losses power i have to pull over put in park and wait a minute before i can start driving again?
Mar 4, 2009 at 4:33 AM
FIXITMR
  • 9,990 POSTS
sounds like a fuel starvation issue?but with that many miles a lot of other things can come into play?hvaing the fuel pressure tested before and after the problem arises would help determine if it's pump or other causes?
Mar 4, 2009 at 7:56 AM
