1994 Ford Tempo power windows not working
1994 FORD TEMPO
D_MAN
Electrical problem
1994 Ford Tempo 4 cyl Front Wheel Drive Automatic
None of the windows are working in my Tempo, the fuse is good & I replaced the circuit breaker just in case but still nothing. I have no power at the switch & I would like to know where the power window relay is located.
Sep 4, 2010 at 2:37 PM
FIXITMR
  • 9,990 POSTS
there should be nothing in between fuse box and switch. if power at breaker fuse but no power at switch, maybe wires damaged in door jamb? also do a search of this tempo forum for power windows.
Sep 4, 2010 at 6:01 PM
D_MAN
I'm not sure if this proper to reply to my own question but I just thought I would let every one know what I came up with.
I did find the relay, it was a green relay located by the fuse panel, & as it turned out it was the relay that was bad. What I actually ended up doing was tapping on the relay with a 1/4" extension & the windows started working. Needless to say I will be picking up a new relay.
Sep 5, 2010 at 5:31 PM
