1994 Ford Tempo locked up tire
KIM SCHULTZ
Tires and Wheels problem
1994 Ford Tempo 4 cyl Two Wheel Drive Manual
had the car parked for about a year- went to move it & the back drivers side tire was locked up. Any ideas?
Feb 19, 2009 at 10:57 AM
  • 75,988 POSTS
Go behind the backing plate and go thru the start wheel adjuster hole and contract the brake shoe.
Feb 19, 2009 at 11:14 AM
FIXITMR
  • 9,989 POSTS
your shoes are rusted to the drum from moisture.ive taken off the wheel and put wd40 thru brake adjuster hole in back(oblong rubber plug)and beat/tapped on drum with hammer till it moved.do an internet(google) search on how to free rear wheel brakes/drums?i've also just driven car on pavement going back and forth and broken it loose.
Feb 19, 2009 at 12:42 PM
