1994 Ford Tempo ILE AIR CONTROL AND MASS AIR SENSOR BAD
1994 FORD TEMPO
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
NSTIGMA2005
A TECH STORE PERFORMED A CHECK ON MY CAR AND SAID THE IDLE AIR CONTROL , MASS AIR FLOW SENSOR AND THE OXYGEN SENSOR NEED REPLACEMENT
I DID THE MASS AIR SENSOR AND MY CAR HAS A STABLE IDLE BUT TO ME IS TO HIGH (MORE THAN THE USUALLY WAS) SO I CHECKED AND CLEANED THE IDLE AIR CONTROL AND IT LOOK LIKE IS NOT WORKING SO WHAT DO YOU RECOMEND CHANGE THE IDLE AIR CONTROL TOO, IS THIS THE REASON THAT MY CAR HAS A HIGH IDLE AFTER I CHANGED THE MASS AIR FLOW SENSOR
AND I NEED REPLECEMENT THE OXYGEN SENSOR TOO O CAN WAIT (don't have to much money)
I'LL BE WAITING FOR YOUR ANSWER
THANK YOU AND HAVE A GREAT TIME
Oct 2, 2010 at 1:25 PM
FIXITMR
  • 9,990 POSTS
you could pick up used IAC from scrapyard to save money? then have money left for new OX sensor. i get IAC used for $5. they guarantee it too.
Oct 3, 2010 at 5:16 AM
