1994 Ford Tempo HOW TO CHANGE THE HEAD LIGHTS
162,122 MILES • 4 CYL • FWD • AUTOMATIC
STANSINGAR
Passenger side headlight to be changed. How could I do that. I can remove the wire from inside but I don't see the bulb. Do I have to remove from the front? I think its a single bulb not he whole set to replace?
Dec 15, 2009 at 7:42 AM
FIXITMR
  • 9,989 POSTS
wire is plugged into bulb assembly. their is a plastic tube shaped lock ring that has to be twisted and then bulb will pull out. it may stick a little cause it has an o ring seal to keep moisture out of headlight. have fun.
Dec 15, 2009 at 8:12 AM
