1994 Ford Tempo fuel
CHRISKELLER
Engine Performance problem
1994 Ford Tempo 6 cyl Front Wheel Drive Automatic
i just changed the fuel pump and fuel filter cause it would shut off like it wasnt getting fuel and after changing that today it shut off again i was wondering if you could tell me what is causing it
Feb 11, 2009 at 5:00 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:e7caf2d8a6="chriskeller"]Engine Performance problem
i just changed the fuel pump and fuel filter cause it would shut off like it wasnt getting fuel and after changing that today it shut off again i was wondering if you could tell me what is causing it[/quote:e7caf2d8a6]
Ok, can you tell me exactly what is happening....
Does it shut off after it warms up?
Are you able to start the vehicle after it cools down?
Is the Check or Service Engine Light on?
Feb 11, 2009 at 5:51 AM
