1994 Ford Tempo Ford Tempo troubles
JENBEN777
  • 1994 FORD TEMPO
  • 4 CYL
  • 12,000 MILES
I will get into my ford tempo and start it, sometimes it takes lots of tries, it will gurgle like its trying to start. Then, after driving for about ten minutes my engine light will come on. Sometimes it dosent. Once the engine light comes on, I notice the idle will change a little, it becomes more uneven. I recently got my oxygen sensor replaced.I dont know what it could be. EGR valve?
Friday, October 16th, 2009 AT 1:24 PM
FIXITMR
  • 9,990 POSTS
When was the last tune-up. Plugs and wires? What color are plug tips? Fords are notorious for bad coil wires. How do internal cap posts look? Are they caked with buildup? Scrape it off! Is the buildup centered? Or of to 1 side? Take the vacuum hose off the egr and plug it(hose). Then drive test it.
Friday, October 16th, 2009 AT 9:19 PM
JENBEN777
Thanks ill give it a try
Monday, October 19th, 2009 AT 10:51 AM
