1994 Ford Tempo Flushing a Radiator
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
TROY_N_ALLY
How do you flush the Radiator
Dec 3, 2007 at 5:36 AM
MERLIN2021
  • 17,250 POSTS
Go get a prestone flush kit, then install the tee on your heater line, open the drain at the bottom of the radiator, this may require the removal of the splash shiel under the engine, Attach a garden hose with the supplied adapter, turn it on after the old coolant is drained, run till water is clear...then drain the water, close radiator, fill with 50-50 antifreeze mix!
Dec 3, 2007 at 5:43 AM
TROY_N_ALLY
[quote:204b64698b="merlin2021"]Go get a prestone flush kit, then install the tee on your heater line, open the drain at the bottom of the radiator, this may require the removal of the splash shiel under the engine, Attach a garden hose with the supplied adapter, turn it on after the old coolant is drained, run till water is clear...then drain the water, close radiator, fill with 50-50 antifreeze mix![/quote:204b64698b]
Where is the drain plug to let whats in the engine out ?
Dec 4, 2007 at 6:50 AM
MERLIN2021
  • 17,250 POSTS
Sorry I miss read the post...I thought you asked about the radiator? >How do you flush the Radiator If the engine needs it, Follow these instructions...
https://images.2carpros.com/forum/automotive_pictures/62217_Flushing_1.jpg
Dec 4, 2007 at 7:38 AM
