1994 Ford Tempo Engine does not crank. After few minutes st
150,000 MILES • 4 CYL • FWD • AUTOMATIC
STANSINGAR
I bought this car last week. So far 3 times, when I start, I hear the fuel filter noise but the engine does not crank. After few tries or after few minutes engine started. It happen in the morning and the evening. Can some one help me please.
Dec 18, 2009 at 9:59 AM
FIXITMR
  • 9,989 POSTS
ok, so your saying that you turn the key to start and the only noise you hear is the humm from pump under rear seat? if this is the case then your relay to starter is not operating.it;s above inner fender under hood drivers side. either it is not receiving power from ignition switch or the connection/ground on relay is bad or ignition switch is out of alignment or going bad. next time it happens pull little rubber plug off relay and and put back on. if it feels to loose pinch it lightly with pliers to make it fit tighter. if this no go rig test light to plug and try again to see if it has juice. if good check fender mounting grounding screws on relay by loose/retighten. if no juice at plug then either the ignition switch is going bad or its out of adjustment. it's under steering colunm under dash. it is operated by wire rod from key which is why it's adjustable.
Feb 7, 2010 at 2:44 PM
