1994 Ford Tempo dash lights
ELLIEJ
1994 Ford Tempo
the fuse number thirteen with and ampage of 5 has gone out twice now in one day. i just recently put in a new deck stereo and this may or may not be affecting the fuse. this problem didn't happen until the next day after i put it in. all the instrument lights go out on the dash but the stereo stays on; i am not sure if the stereo is connected with this fuse. the fuse doesnt go out right away when im driving or right away when i turn the stereo on but it randomly choses to go out.
Dec 30, 2009 at 6:55 AM
FIXITMR
  • 9,989 POSTS
does the stereo light go out too? have you tried a bigger amp fuse?
Feb 7, 2010 at 1:23 PM
ELLIEJ
i tried an amp of ten and that went out too not right away but it did go out. then the new deck got stolen out of my car. i put in the stock radio again and i havent tried another fuse yet because when i turn the headlights on the clock light goes off on the stock radio and when i turn the headlights back off the clock light comes back on. could this be a ground wire missing with the stock radio?
Feb 7, 2010 at 2:16 PM
FIXITMR
  • 9,989 POSTS
the radio has daylight/night light brightness controlled by the lightswitch maybe? not sure. does the fuse blow have anything to do with your lightswitch position? could pop a used switch in to test? if you have the switch in the side of speedometer shroud then it just pop/pry/wiggles out.
Feb 8, 2010 at 3:02 PM
