1994 Ford Tempo Compressor
1994 FORD TEMPO
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
RATTANAS
The compressor will only engage if it is hot wired directly from the battery. There is power to the a/c cycling switch. When the compressor clutch engages, the system cools properly. I tried replacing the power control module, but did not fix it. Where else should I look for a break in the circuit.
Apr 29, 2008 at 9:32 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Hi there,
get the internal pressures tested first, there may be a problem that has caused the high or low pressure cut out switch to operate.
Mark (mhpautos)
Apr 30, 2008 at 12:24 AM
