1994 Ford Tempo car horn
126,000 MILES • 4 CYL • FWD • AUTOMATIC
TANDMBPIERCE
The car horn does not work. We do not have an owners manual. Could this be a blown fuse? If so, which one and where? Other than that, what other options do I have for repair.
Jun 24, 2008 at 1:50 PM
LEGITIMATE007
  • 5,121 POSTS
yes it could be a blown fuse and your fuse box should be right by your left knee under the dash, if not then check right on the left side of the dash near the door handle, and if this is not the case then get a test light and check to see if your getting power at the horn, if you are then it may be the horn if not then it could be the horn button
Jun 24, 2008 at 3:29 PM
