1994 Ford Tempo blower motor not working
1994 FORD TEMPO
78,000 MILES • 4 CYL • FWD • AUTOMATIC
CHADP894
The fuse is good. But we are not getting power to the switch to turn the blower on.
May 9, 2009 at 7:01 AM
FIXITMR
  • 9,990 POSTS
so when did this happen? any other issues before or after this problem? you can try tracing the wire back to fuse box?or just drop box and look for burnt wire on back. the tempo system is famous for burnt off melted connectors on blower circuit! you can also just run a heavy hot wire from battery to fan switch.
May 10, 2009 at 5:38 PM
