1994 Ford Tempo Blower Motor
142,000 MILES • 4 CYL • FWD • AUTOMATIC
GENOSWRENCH
Could you tell me where the blower motor is located?
Dec 25, 2008 at 10:36 AM
DAVE H
  • 13,383 POSTS
BLOWER MOTOR
Removal & Installation
Disconnect negative battery cable. Disable air bag system. Remove glove box. Remove right and left "A" pillar trim moldings. Remove right and left kick panels. Remove lower instrument panel-to-cowl screws. Remove instrument panel vertical brace retaining nuts located left of glove box.
Disconnect blower motor resistor harness connector. Remove 3 screws attaching blower motor and mounting plate to heater case. Gently pull instrument panel away from right side of cowl panel, until blower motor can be removed. Remove motor and mounting plate from vehicle. To install, reverse removal procedure.
Dec 25, 2008 at 11:11 AM
