1994 Ford Tempo
ONEYZKING
Engine Mechanical problem
1994 Ford Tempo 4 cyl Front Wheel Drive Automatic
I have changed a harmonic balancer in an f-150 before but there was alot more room.My question is how do you change the harmonic balancer when the frame is almost up against the pulley?
Aug 16, 2009 at 11:22 AM
FIXITMR
  • 9,989 POSTS
should be able to get it by taking wheel off and maybe dropping motor mount although that may not be necessary?
Aug 16, 2009 at 3:29 PM
ONEYZKING
thank you for your reply.I will try that and get back to you.
Aug 16, 2009 at 11:56 PM
