1994 Ford Tempo
1994 FORD TEMPO
23,000 MILES • 4 CYL • FWD • AUTOMATIC
MLACHNIK
broke spark plug off and then broke off easy out and need procedure to remove head.
The main question is do I need to remove the injectors to remove the intake manifold. I have all the bolt loose. However, it seems to be giving me trouble to get loose.
Thank you
Larry
Sep 22, 2009 at 4:03 AM
FIXITMR
  • 9,990 POSTS
which hole was it? you could go to shop and have them try to burn out plug/ezout with torch. the aluminum head absorbs heat while the steel plug/ez sucks it up and melts! might work? better than taking off head?
Sep 22, 2009 at 6:34 PM
