1994 Ford Tempo
1994 FORD TEMPO
DEBBYPHOTIS
Engine Cooling problem
1994 Ford Tempo 4 cyl Front Wheel Drive 125000 miles
what would tell you if you have a blown head gascet
Mar 6, 2009 at 8:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The only way to know for sure is to remove the head and have it magnafluxed because if the gasket is bad there is always a possiblity of the head itself being damaged as well. When the head is removed you can inspect the gasket. But a simple quick test is to, with engine hot, remove dipstick and drop a bit of oil on hot manifold or other hot part of engine, oil will smoke and water will sizzle. Signs of water/antifreeze in oil is an indication that head gasket is leaking .
Thanks for using 2CarPros.com!
Mar 6, 2009 at 9:14 AM
