1993 Ford Tempo waterpump
1993 FORD TEMPO
137,000 MILES • 4 CYL • FWD • AUTOMATIC
GRAYLADY
how do i get to the waterpump w/out pulling the engine
out.
Jul 20, 2010 at 12:09 PM
EDWARD.S
  • 166 POSTS
Hi, You Can Get The water Pump Out ,Without Removing the Engine .It's much Easier On A lift, But If you Don't Have That It can be done On Drive On ramps You Remove it From under the Passenger side Of the car.When you do this job Remove the Whole Housing Out Of The Car.Lower The Pipe That runs along The Oil pan To goes Into The housing.
Hope This Helps You,
Good Luck
Edward S.
Jul 20, 2010 at 12:23 PM
