Transmission problem
1993 Ford Tempo 4 cyl Automatic
where do you add fluid
Jul 5, 2009 at 4:09 AM
FIXITMR
✓Experienced Mechanic
look down beside battery right behind radiator and you should spot dipstick handle. add it there. your air duct is sorta in the way if it's still attached to that plastic unit right across top of radiator. i removed mine and left it off. has no functional purpose really.
