1993 Ford Tempo temp guage
CAR CARE
  • 1993 FORD TEMPO
  • 4 CYL
  • 34,205 MILES
My temp gauge isnt working, I want to fix it. How do I fix
Friday, May 14th, 2010 AT 10:10 AM
FIXITMR
  • 9,990 POSTS
Check the single post connection for loose/off/corrosion at the sender which is under the thermostat housing where upper radiator hose goes into head. Sender could also be bad? Take wire off sender and touch to clean bare metal. The gauge should max out hot! This tells you gauge and wiring are ok, change sender.
Friday, May 14th, 2010 AT 2:17 PM
