1993 Ford Tempo Starter Motor
53,000 MILES • 4 CYL • 2WD • AUTOMATIC
GCARMODY
Took it to O'Rileys. Tested O.K. Relay clicked when I turned the key. Replaced Relay anyway. Replaced selenoid(SP?). Replaced igniion key and electrical connector. Checked all fuse links with an ohm meter. The all showed closed connections. Removed spark plugs and easily turned the crankshaft. So engine does not seem to be seized. Any help or suggestions would be greatly appreciated.
Nov 21, 2008 at 12:04 AM
DAVE H
  • 13,383 POSTS
could be a bad ground/earth connection on starter ?
https://images.2carpros.com/forum/automotive_pictures/266999_starter_1.jpg
Nov 21, 2008 at 12:27 AM
