1993 Ford Tempo removing altenator
GRSWETS
Electrical problem
1993 Ford Tempo 6 cyl Front Wheel Drive Automatic
Are there any tricks to removing the altenator?
Jun 28, 2009 at 5:18 AM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable.
Disconnect alternator wire harness.
Remove drive belt. Remove alternator pivot and mounting bolts and remove alternator from bracket. To install, reverse removal procedure
Jun 28, 2009 at 5:37 AM
