HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Tempo
Electrical
Alternator
Replace/Remove
1993 Ford Tempo removing altenator
GRSWETS
MEMBER
1993 FORD TEMPO
Electrical problem
1993 Ford Tempo 6 cyl Front Wheel Drive Automatic
Are there any tricks to removing the altenator?
Sunday, June 28th, 2009 AT 12:18 PM
BMRFIXIT
MECHANIC
Disconnect negative battery cable.
Disconnect alternator wire harness.
Remove drive belt. Remove alternator pivot and mounting bolts and remove alternator from bracket. To install, reverse removal procedure
SPONSORED LINKS
Sunday, June 28th, 2009 AT 12:37 PM
Please
login
or
register
to post a reply.
Related Alternator Replace/Remove Content
94 Tempo
94 Ford Tempo Car Cranks Very Slowly. Battery Tested Good And Fully Charged, Starter Tested Good. Help
Asked by
grillguy
1994
FORD TEMPO
VIDEO
Alternator Replacement
Instructional repair video
GUIDE
Got a red battery warning light on? This most likely means the alternator has gone out and needs a replacement. To confirm the failure use a voltmeter to test the alternator...
That Damm Tempo
1993 Ford Tempo. I Dorve To Work With The Car Missfiering After Every Bump. Took A Look To Find Number 2 Cylinder Plug Wire Loose. Boot Came...
Asked by
koodb
1993
FORD TEMPO
1993 For Tempo
1993 For Tempo. I Dorve To Work With The Car Missfiering After Every Bump. Took A Look To Find Number 2 Cylinder Plug Wire Loose. Boot Came...
Asked by
koodb
1 ANSWER
1993
FORD TEMPO
1994 Ford Tempo Cooling System & Altenator
Does The Altenator And Drive Belt Operate The The Radiator Fan And The Power Steering Unit? I Have No Power Steering And The Engine Heats...
Asked by
TW DUNKIN
1994
FORD TEMPO
1994 Ford Tempo Alternator
I Know Ive Asked A Couple Of Questions About My Car And It Was About The Stalling At A Stop But I Had Someone Look At It And The Motor Does...
Asked by
moorelamar
1 ANSWER
1994
FORD TEMPO
VIEW MORE
SPONSORED LINKS
Online car repair manuals
