1993 Ford Tempo Rack and Pinion Unit leaking fluid
1993 FORD TEMPO
92,200 MILES • 4 CYL • 2WD • AUTOMATIC
LINK00SEVEN
  • 18 POSTS
I currently have a leak in my rack and pinion unit. When my dad took a look at it, he said it looked like it was just the driver-side seal that was leaking, so we were both wondering if it is possible to just replace the seal somehow without taking off the entire unit, or if the entire unit has to just be replaced.
Thanks.
Oct 5, 2008 at 7:21 AM
DOCFIXIT
  • 18,828 POSTS
Hi LinkOOseven
Any leak in the rack assembly other than a line requires removal of rack. When a seal goes and allows fluid to leak out of the dust boot a bushing has worn considerably. Repair is not cost effective rebuilt units are the way to go.
You may try some power steering sealer but eventualy you will need to replace.
Good luck
Thanks for donation
Let me know if you have more questions
On this site go to Popular links click on car replacement parts for rack $$
Oct 5, 2008 at 7:42 AM
