1993 Ford Tempo Passenger Door Lock
163,000 MILES • 4 CYL • 2WD • MANUAL
MCBRIDE7
The driver-side rear passenger door is stuck closed in the locked position. A family member of mine also has a 1990 Ford Tempo with the exact same problem. Are there any ideas to try "loosening" and fixing it ourselves? Or is it probably too complex to where a mechanic will need to fix it? If so, any guestimate on how much it might cost?
Nov 11, 2008 at 10:50 AM
  • 110,248 POSTS
Hi:
remove the door panel and check to make sure the linkage to the lock assembly is still attached. I can't give an estimate because I don't know what is wrong at this point.
Jan 5, 2009 at 7:44 AM
FIXITMR
  • 9,989 POSTS
are the locks manual or electric?i have seen most electric locks freeze up because of rust/.corrosion.the rubber accordian seal fails and moisture does it's job.there is no lubrication on the mechanism.it's basically a push pull magnet tube with a spiral grooved actuator rod.this is to assure no accidental vibration/jar induced movement.also means very difficult to budge when corroded.i have gotten a few to move by grabbing lock post with pliers and pulling hard.good luck!
Jan 31, 2009 at 5:27 AM
