1993 Ford Tempo main seal
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MILKBONE43
how would i repair or how much would it cost to hire some one to repair a main oil seal.
the oil leak is coming from a small line close to my front right axel. some one told me it mighr be called a crank seal to.. any thoughts??
Nov 19, 2008 at 11:34 AM
  • 110,248 POSTS
HI:
Is the oil coming from a steel line / hose? If so, it isn't the crank seal. Are you sure it's leaking engine oil and not ATF?
Jan 5, 2009 at 7:39 AM
