1993 Ford Tempo help with fuses/restoring interior/dashboar
14,967 MILES • 6 CYL • 2WD • AUTOMATIC
SINGINJOY
My husband has tried in vain to fix the taillights, interior lights,and dashboard lights. The brakelights are working fine. He has checked all the fuses under the dashboard, and they appear to be working okay. Is there someplace else he is supposed to be looking at/working on? Thanks-Kristin.
Sep 10, 2008 at 12:02 PM
2CARPRO JACK
  • 11,533 POSTS
Need to test fuses with atest light to be sure they have power to them as well as through them.If ok, gain access top headlight switch, test tan/white wire and black/orange for power, if ok test brown wire for power with headlights on, this is for the running/parking lights.All of the things you mention go through the headlight switch
Sep 11, 2008 at 1:08 AM
