1993 Ford Tempo harmonic balancer
KUESTER2
Engine Performance problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic
how do you install a harmonic balancer?
Apr 30, 2009 at 10:23 AM
MMPRINCE4000
  • 8,548 POSTS
You can get a loaner tool from most autoparts stores. It threads into crankshaft threads, put a thrust bearing next to balancer and drive the balancer in.
While some people put balancer on, then use balance bolt on and tighten it to drive balancer on, you CAN strip the threads on the crankshaft using this method.........this is not a good thing.
May 1, 2009 at 12:05 AM
