1993 Ford Tempo fuel system issu ?
100,000 MILES • 4 CYL • FWD • AUTOMATIC
DANNYR2009
  • 30 POSTS
After doing 100km on highway, all went well. The car was running well, idle when parked and i turn it off. About 2 mins after, i fired it back up and start right away but the idling was real bad ! Like if there were not enough fuel or fire was too weak! After like 5 sec of bad idling i decided to turn it off. Turn back on and it start but idle again bad, i tried giving gas, no change than after another 5 sec, it died. Tried to start it up again, engine was cranking okay and fast enough like normal but will not start.
I unplug the fuel filter, the side going to the engine and saw fuel pressure was present, so i plug it back in...
the reason why i am thinking it's fuel related is like for 2 months, when i turn the key to ON position, i can hear a bubling sound coming from where i think is in the tank. Sounds like the fuel pump. The fuel pump have been changed about 3 months ago so i don't think it's related with the pump itself.
I can remember that yesterday before starting the car, i can only hear the Tick which the fuel pump does before cranking the engine, i didn't hear the 3 seconds buzzing sound or bubling sound. (because sometimes it does the buzzing sound and sometimes, more often lately, the bubling sound)
What can i check for issu ? Can the fuel pump relay do that ? Fuel pressure regulator ?
Oh yeah...by the way, later that night i tried the car for the heck of it and it started ! So i was able to go home, but didn't stop the car before arriving home. This morning i started the car to go work and all is good...
Someone having an idea what's wrong or what to check ?
I will get myself a fuel pressure gauge pretty soon, i will have something to check if that happen again soon...
Dan
Nov 9, 2009 at 3:11 AM
FIXITMR
  • 9,989 POSTS
sounds like it's electrical related. ford has a test port that has a fuel pump test lead that you can apply 12v to test pump. i think it's over by upper passenger shock tower under hood. it's a plug on the end of a harness. 1 has like 5 inputs and the pump test plug has 1. that's how i remember it.
if you dont hear pump when turning key to on, then it shouldn't start.
Nov 11, 2009 at 2:40 PM
DANNYR2009
  • 30 POSTS
I used the car all week, it's my primary car so i start it like 8 times a day and started right away each time. Never did it again...
When the issu was present, i only heard a tick after 2-3 secs the key was turn to on. No humming sound before...
When the car start okay, when i turn the key to on, i start to hear right away a humming sound from the pump for 2-3 second than it stop, turn the key to start and the engine start right up.
I learn by reading posts that this car doesn't have a fuel pump relay, it got a module which include several really like the fuel pump, fan engine and other thing...it's the ccrm (constant control relay module)...
Might check to see if i can get it from a scrapyard closeby and swap it...what do you think of that ?
I'll check the test connection port to hook up 12 volts to see if it would start up...if it does once again, i will have something to try...
Thanks again,
Danny
Nov 12, 2009 at 6:12 AM
FIXITMR
  • 9,989 POSTS
ya my book says in 92 they used a new relay system all in 1? i'll have to grab 1 of those from boneyard myself as i have a 91 and 92 and didn't know they were different! thanks
Nov 13, 2009 at 6:36 PM
DANNYR2009
  • 30 POSTS
man, they should of stick with individual relays huh? Anyhow, i think i'll leave it just like that because i've been threw all week and all weekend without a trouble ! Started right up.
One time like a year ago the heater /ac blower motor wasn't working at all and it was like -30 celcius outside and really needed that fan to work. After checking this and that...without changing any parts, it start running by itself like 20 mins after.
I thought i would change some parts making sure it will not happen again but actually i didn't and it still works....maybe just a bad contact...
it's true that asking for that module in a scapyard would be like 60 bucks or some and if that happen again and i get stuck..a recker will be more!
A risk i am willing to take
Thx for your help,
Dan
Nov 16, 2009 at 12:19 AM
DANNYR2009
  • 30 POSTS
lol...i forgot about that post, actually the issu got worst, now the car won't start when hot (no fuel pump) but will work when cold.
Yesterday i swap the ccrm with one i got from a scrapward and the issu remains, so it's not it...i'll be swaping the engine computer tonight...heard it's a real pain to get it out...we shall see.
Dan
Apr 14, 2010 at 1:32 AM
