1993 Ford Tempo erratic idle
110,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN TEMPO93
when stopped or in park engine idle is eratic.most of the time it seems too go lower almost to a stall ,sometimes causing slight jerkin.
Aug 16, 2009 at 7:45 AM
  • 75,988 POSTS
Do you have a check engine light and when was the last tune-up??
Clean out the idle air control valve and EGR valve and test the throttle position sensor.
Aug 16, 2009 at 9:05 AM
