While driving and no brakes just let off the gas and it idles for a minute and dies
same with the first start of the day you have to crank it for a while when it finally turns over and is started you got to put it in gear and drive or it will hesitate start shaking and die if you try to pump the gas pedel it backfires and still eventualy dies im thinking its the fuel pump egr valve or the ignition timing unit
Monday, February 8th, 2010 AT 7:06 PM
