1990 Ford Tempo car cuts off
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHARLIEBOYSL
I have a 1090 ford Tempo It cuts off every month I have replaced almost everything , the filters the gas pump the low speed jets and with out notice or showing any symtom it cuts off later it will restart
Apr 6, 2009 at 9:49 AM
FIXITMR
  • 9,989 POSTS
sorry,not enough specific replacement info. besides,if it starts right back up live with it till the part that is causing problem dies completely? could also be an electrical connection corroded/loose on a car that old!
Apr 6, 2009 at 12:26 PM
CHARLIEBOYSL
Some times its an hour or two
Apr 6, 2009 at 12:30 PM
FIXITMR
  • 9,989 POSTS
when it happens put a little gas in carb and try to start again. if no go check for spark. have you replaced any of the ignition parts?coil wire is big problem for fords.are you saying this only happens when car is warmed up?you have to supply more details to get better/accurate advice.
Apr 7, 2009 at 9:39 AM
CHARLIEBOYSL
Only happends when car is hot and there is no carberator
Apr 7, 2009 at 9:42 AM
FIXITMR
  • 9,989 POSTS
so what are "low speed jets"?you got multiport or throttle body injection!with throttle body it's easy to remove rubber duct and put some gas in! have you changed ignition module/distributor?coil?coil wire? i usually just get a complete distributor assembly with wires from the boneyard. being it's a hot only event i suspect the ignition module or electrical internal distributor parts. what do the plugs/plug gaps look like? i had this tempo that would finally not start or stall alot and new plugs always fixed it! about every year or so!
Apr 7, 2009 at 9:11 PM
