1993 Ford Tempo engine rattle noise at idle speed
130,000 MILES • 4 CYL • FWD • AUTOMATIC
WAYKOALA7
noise quits when i run engine with belt off
i've heard the crankshaft pulley makes noise. is this the only thing or could it be the air conditioner which increases noise when it is on?
Mar 26, 2010 at 12:11 PM
FIXITMR
  • 9,989 POSTS
weird, that you mention it, i just noticed a similar noise on my grandaughters tempo. put belt back on and try to pinpoint with a tubing held to your ear like sweeper wand or pvc pipe.i have never actually had 1 go bad on a tempo.(crank pulley/harmonic balancer) thanks
Mar 26, 2010 at 1:59 PM
